LunchBox problem with Splitted Surfaces
Hello guys, i’ve made this surface using rhino and i splitted it.
Now i’m trying to realize Diamond Panels with that surface but the splitteed part come out. How can i fix this?
link immages : https://ibb.co/n0BkFLz and https://ibb.co/JFWRQNw
Dear @zifo.ar
You will have to work with an untrimmed surface in order to archive the desired result. You can also get the curves (Diamond and Triangular Panels ) and project/pull the into the surface.
Cheers.
okok so now i m gonna remake that surface, thank you a lot :slight_smile:
I tried to remake the surface but i,ve got the same problem… The Dyiamond Panel still take too much area around my shape …
Dear Zifo,
I am pretty sure that this is a Trimmed Surface, see an example.
See also a way to solve the problem.
Cheers
Thank you a lot, i relly appreciate it ! :slight_smile: Do you know how to make a “panel frame” now ? because i’m stuck there
You can offset the curve and either loft the curve or trim the surface.
