Lunchbox panels on subd form!
Hello everyone, I’m new to using subd and grasshoper, so I’m sure I have a simple problem. My issue is that I have a complex subd surface and I tried to create some panels on it with lunchbox but panels are created for each subd surfaces, and they caused weird connections. How can I solve this poblem? tnx
You can’t. LunchBox is meant to work on singular surfaces. Your form would probably yield a polysurface, which is composed of multiple subsurfaces. Each of these surfaces would get individually divided, but you won’t be able to easily map a coherent pattern/tessellation over the entire form.
That said, depending on what you want to do pattern-wise, you can extract the mesh control polygon from the SubD and go from there. Triangulations and hexagonal tessellations are very easy to do with Grasshopper.
