Hello. I am trying to panelize the surface using LunchBox plugin option…
The panelized surface should be the one that is selected (marked in yellow) in the screenshot below.
But the system recognized the area (marked in red) as a refference surface which is not what I wanted.
Also, the output geometry is classified as closed Brep.
What changes can/ must be done to reclassify the closed Brep to a surface?
Another question: how do you refference a command/ component to a comment in the forum? (As you did with “Region Intersection”) SVIESA- TAMSA_re2.gh (171.3 KB)
