I tried to trim the surface but the output is still rectangular, so I tried to intersect it with the extrusion of the base curve (capped holes) but some parts were cut and others still ended outside the boundary of the form. How do I fix this?
I had this problem too. This is the answer I got. Lunchbox footwear - #3 by JP-Mike
Thank you so much. I checked the image, and it had a ‘duplicate border’ command, where can I find this?
I didn’t have it either. I just used dupborder in rhino and set that crv in grasshopper.
Hi , Duplicate Boarder component you can get it from Fennec Plugin
check it out
If you upload your GH file you will get more help .
