Lofting from two closed curves to one closed curve
could any one help me loft these sections where two curves become one and vice versa?
test.3dm (272.1 KB)
hi.. mm not sure if this is what you are searching…. so in this solution I made 2 different blend srf
then I splitted it
then I transform it to mesh
then quadremesh to have a workable subd (and dorking on it.. making a nice subd bridge..etc)
Then keeping only the “Y” joint form the subd
and finally making some blendsrf using this joint.
Hi, thank you this is awesome! Would you mind sharing the Rhino file you worked on?
Dear Camilla.. I didn’t save the file.. I’m sorry..
Thanks for your help nonetheless
