Hey I’m somewhat still new to rhino and having trouble connecting the gap between one closed curve and two closed curves. I’ve tried building curve bridges for sweep 2 and blendsrf but nothing seems to work cleanly.
Hi Zusha - this can certainly be done with surfaces, but depending on the desired use, the result may be a lot simpler and more tractable and editable if you make this type of branching shape from SubD.
