Help with the creation of a surface that goes from one curve to another
Hello
i am a first year architecture student and i need some help in devising a way to approach this problem. in effect i need to take the curves on one side of this cube and connect it to a curve on the other. so what i need to get out of this is a surface or a series of lines that have the colored drawing as the base and the black and white drawing as the top. i hope this makes sense. i know that there must be a way to do this with commands.
Thank you for any and all assistance,
Adam Champagne
Hmmm - if you can pick out one colored curve and one line on the opposite side that go together, you can Loft between the two, but I’m not sure that is really what you are after.
what do you mean by loft? is it a command and how does it work? but it think you are understanding the idea properly.
Thanks, Adam
Hi Adam - see the Loft (Surface menu) command, & Help for basic info.
