Loft Option is Grasshopper
I am having difficulty with the loft option i am check two methods it work well in one (right side of the attached picture) & it does not work in the other.
Could someone please clarify this issue.
Loft.gh (4.7 KB)
Loft.3dm (63.2 KB)
BR,
J.Randeep
The curves in the second example are oriented in opposite directions. Flip one or the other in Rhino, or use Curve>Util>Flip Curve in Gh.
Thanks for the reply
I tried as you instructed still it is twisted somehow
I’m still not clear on why it’s ok in one instance and not the other because in both examples the two curves have different number of discontinuities. I tried shifting points with slight improvement, but this fix should work.
Loftb.gh (6.6 KB)
Thanks a lot it worked perfectly.
BR,
J.Randeep
I’m having a similar problem with loft.
Could you post the .3dm file in a Rhino5 version ? I’d like to check out the solution you guys found
Thanks
Please find the attached.
BR,
J.RandeepLoft.3dm (63.2 KB)
Thanks
