I am trying to loft these curves and the lofting component is getting crazy. I assume it is because of the curves directions. Would you like someone to help Please?
lofting curves different direction.gh (8.3 KB)
Please, internalize your data or attach rhino file also.
Use Flip component
Here we go!!!
lofting curves different direction.gh (20.0 KB)
There are many curves with different directions. FYI I tried it since yesterday afternoon but that component didn’t work ;(
Did you try running them all through the same component?
My memory is a little sketchy, I had a similar problem a few yrs back, I recall that fixed it.
At the beginning yes. Later a use the first curve as a guide but it didn’t work ;(
lofting curves different direction_re.gh (56.7 KB)
Your file was strangely very heavy for my rhino…
Have a look and see if it helps.
You are GENIUS. Thank you so much Do you have a youtube chanel?
Sorry Mate. I am working on a huge wall. Thank you for the effort
Thank you GrassMateHoppers
