Loft 2 different profiles along a curve in GH
Hi all,
I wanted to loft a circle and a rectangle along a curve in Grasshopper…
Any thoughts?
You’re not specifying what you want this to look like?
(For example, smoothly transition from circle to rectangle or transform along the curve somehow - there’s no ‘loft along curve’ component)
You can use ‘Sweep1’ and use both the circle and the rectangle as your section profiles.
Just make sure they’re aligned.
