Lists matching
Hi just trying to get these lists to loft vertically, how can i organise the list to do so?
Hard to gather what is going on there, if you haven’t figured it out you will need to provide clear direction and/or an internalized GH file of the issue.
millipede forum.gh (92.1 KB)
Thanks Rickson, here is the file I have annotated inside
Wow! Warning to others… disable the solver before opening this file! Still waiting to see the model…
P.S. Whatever it is you’re trying to do, I suggest you perfect it with a small fraction of the ~2,500 points you are using. The model is so unresponsive (R5, old laptop) that it’s impossible to study and modify.
P.P.S. It’s not so much the number of points, it’s the fact that they are so very far away from the origin that makes the model impossibly slow. This is the Average of your 2500 points: {433195.1697112, -211279.5796937, 145.8802954}
I personally prefer the weave component with grafted inputs.
like Joseph said, its too for from the origin.
you are close, just need to know how to match lists.
RE_millipede forum.gh (95.1 KB)
Thank you so much, and the video is great too!
I was not aware of this thank you!
