How Do I Make the List Take Points Horizontally Instead of Vertically?
Hi all, I just want to fix this issue of the list taking in points vertically, I want the list to highlight the geometry layer by layer horizontally, any help would be appreciated.
STL Canoot.gh (34.2 KB)
Use Flip Matrix
STL Canoot_01.gh (29.8 KB)
Thanks, and if I want to select multiple layers, for example 0 to 300 from the list, how would I do it, I tried to add a panel and type 0 to 300 and it didn’t work
You’re welcome . This is one way of doing this :
STL Canoot_02.gh (32.4 KB)
This is another :
STL Canoot_03.gh (31.9 KB)
Works if the input type is Domain . I guess he connected that to index input of List item that’s why it didn’t work
Not necessarily :
Thank you. I deleted my post.
Why did you unmarked the solution if it helped you !?
Hi Ali, can you let me know I can get the first half of this polyline, the method you taught me did not work when I have a polyline spiral.
Also, the “LiNear Movement” component does not read the polyline, is me dividing it to points the correct approach?
Thanks for your help
STL Canoot_01 (1).gh (33.6 KB)
Please make a new thread for new questions.
Also, Ali's method works just fine:
