Hello everyone, I hope you can solve this problem that I saw working on Wallacei Analytics; I don’t know if it is a bug problem or is related to calling the values.
I am working on a project for my master’s thesis, and right now, I am setting up the output graphs.
Wallacei is amazing in showing data analytics; the problem is that when I want to use the diamond component to get the fitness values and the graph, only one of them matches my values.
As I show in the image, I have placed the values obtained from the results; these were obtained from the phenotype node.
I thought I had made a mistake mapping the values, so I checked it in the UI analytics, and it showed me the same errors. However, a detail that confused me a bit is the inversion of the values that; in the beginning, I thought I was doing it wrong, but when I tried to place it as it appears in the graph, it appeared to me that it was out of range.
I hope you can guide me regarding this, which apparently is a bug; if you have had something similar, I would appreciate it if you could tell me how you could solve it.
