Hi there – I think this is a pretty simple one, but I can’t wrap my head around it. I have an axis of rotation with centerlines perpendicular to it. The goal is to have a general, sweeping up motion starting from a vertical curve and ending with a horizontal curve. The TweenCrv node achieves what I want, but not from the rotation axis that I want, so I built that into the script, but then it sends the curves off in different directions.
Goal (but with rotation along the interpolated axis):
Too late, @HS_Kim has a special place in his heart for people who don’t follow forum etiquette.
I can’t see much but one thing is pretty obvious; you are passing degrees to RotAx but haven’t switched that component to accept degrees (right-click the ‘A’ input):
I thought I was achieving the degrees required for input with the radian / degree conversion (connected to it). Is that not correct? Thank you for your help.
@HS_Kim Thank you for your response – this does what I think I had covered in the longer version of my script, but what I need is for the rotation to occur at a different point, so another axis perpendicular to each curve (not from the top / end point). How might I achieve that?
