I have made a script in one system and when I use the same script in other computer, curves seems to be flipped. Also order of curves and points changes for example if points are arranged 0,1,2,3 for 4 corner points of rectangle clockwise in one script its arranged anti clockwise in other script. So if I use list to extract point 3 it extracts point 1 in other computer.
May I know why this happens ? Kindly help @DavidRutten @PeterFotiadis
Willem
(Willem Derks)
December 17, 2019, 8:38am
2
Could it be the views are not equal.
If the geometry is flipped it could be one Rhino is looking at the bottom while the other is looking at the top.
Best would be to post the files here so others can have a look at it, the cause is hard to tell with no file at hand.
-Willem
that is tricky to post file because for you it might work and for others it will be different. Ok I will post a script let me know what you see. Kindly post top view.
Flipped_Curve_bug.gh (4.7 KB)
Kindly check this and post the top view please.
Flipped_Curve_bug-01.gh (7.7 KB)
aha look at my top view. strange huh @Willem
try adding xy plane to bounding box and see it shows same like me please
Willem
(Willem Derks)
December 17, 2019, 10:27am
9
Can you save the Rhino file you are working with, so I can compare it with mine.
Kindly look at the baked curves in my rhino file.
Flipped_Curve_bug-01.3dm (23.2 KB)
so weird. This makes me crazy because fixing scripts many times if its uploaded in different system
Willem
(Willem Derks)
December 17, 2019, 10:35am
12
I still get a different result.
can you run the SystemInfo command and paste the report here to see if we run the same Rhino verions
Rhino 6 SR21 2019-12-9 (Rhino 6, 6.21.19343.07571, Git hash:master @ 065e51d4aa4ae930b9c028f94e211dd62b201f8f)
License type: Commercial, build 2019-12-09
License details: Cloud Zoo. In use by: Willem Derks ()
Windows 10.0 SR0.0 or greater (Physical RAM: 32Gb)
Machine name: WD10
Hybrid graphics system.
Primary display: Intel(R) HD Graphics 630 (Intel) Memory: 1GB, Driver date: 5-17-2017 (M-D-Y).
Primary OpenGL: NVIDIA GeForce GTX 1070 (NVidia) Memory: 8GB, Driver date: 3-17-2019 (M-D-Y). OpenGL Ver: 4.6.0 NVIDIA 419.67
OpenGL Settings
Safe mode: Off
Anti-alias mode: 4x
Mip Map Filtering: Linear
Render version: 4.6
Shading Language: 4.60 NVIDIA
Driver Date: 3-17-2019
Driver Version: 25.21.14.1967
Z-Buffer depth: 24 bits
Total Video Memory: 8 GB
Rhino plugins
C:\Program Files\Rhino 6\Plug-ins\Commands.rhp "Commands" 6.21.19343.7571
C:\Program Files\Rhino 6\Plug-ins\WebBrowser.rhp "WebBrowser"
C:\Program Files\Rhino 6\Plug-ins\rdk.rhp "Renderer Development Kit"
C:\Program Files\Rhino 6\Plug-ins\RhinoScript.rhp "RhinoScript"
C:\Program Files\Rhino 6\Plug-ins\IdleProcessor.rhp "IdleProcessor"
C:\Program Files\Rhino 6\Plug-ins\RhinoRender.rhp "Rhino Render"
C:\Program Files\Rhino 6\Plug-ins\rdk_etoui.rhp "RDK_EtoUI" 6.21.19343.7571
C:\Program Files\Rhino 6\Plug-ins\rdk_ui.rhp "Renderer Development Kit UI"
C:\Program Files\Rhino 6\Plug-ins\NamedSnapshots.rhp "Snapshots"
C:\Program Files\Rhino 6\Plug-ins\Alerter.rhp "Alerter"
C:\Program Files\Rhino 6\Plug-ins\IronPython\RhinoDLR_Python.rhp "IronPython" 6.21.19343.7571
C:\Program Files\Rhino 6\Plug-ins\RhinoCycles.rhp "RhinoCycles" 6.21.19343.7571
C:\Program Files\Rhino 6\Plug-ins\Grasshopper\GrasshopperPlugin.rhp "Grasshopper" 6.21.19343.7571
C:\Program Files\Rhino 6\Plug-ins\Toolbars\Toolbars.rhp "Toolbars" 6.21.19343.7571
C:\Program Files\Rhino 6\Plug-ins\3dxrhino.rhp "3Dconnexion 3D Mouse"
C:\Program Files\Rhino 6\Plug-ins\Displacement.rhp "Displacement"
C:\Users\Willem\AppData\Roaming\McNeel\Rhinoceros\packages\6.0\rhino-render-next\0.0.2\RhinoRenderNext.rhp "Rhino Render Next" 0.0.2.0
Rhino 6 SR19 2019-10-22 (Rhino 6, 6.19.19295.01001, Git hash:master @ 0af62045bd35259d4c2367dbf7f9ef94ded29299)
License type: Evaluation, build 2019-10-22
License details: Stand-Alone
Expires on: 2020-02-14
Windows 10.0 SR0.0 or greater (Physical RAM: 16Gb)
Machine name: MURALI-CRAFT
Non-hybrid graphics.
Primary display and OpenGL: Intel® UHD Graphics 630 (Intel) Memory: 1GB, Driver date: 6-12-2019 (M-D-Y). OpenGL Ver: 4.6.0 - Build 26.20.100.6952
OpenGL Settings
Safe mode: Off
Anti-alias mode: 4x
Vendor Name: Intel
Render version: 4.6
Shading Language: 4.60 - Build 26.20.100.6952
Driver Date: 6-12-2019
Driver Version: 26.20.100.6952
Total Video Memory: 1 GB
Rhino plugins
C:\Program Files\Geometry Gym\Rhino3d\ggRhinoIFC.rhp “ggRhinoIFC” 1.7.11.0
C:\Program Files\Rhino 6\Plug-ins\Commands.rhp “Commands” 6.19.19295.1001
C:\Program Files\Geometry Gym\Rhino3d\BullAnt.rhp “bullant” 1.4.4.0
C:\Program Files\Rhino 6\Plug-ins\rdk_etoui.rhp “RDK_EtoUI” 6.19.19295.1001
C:\Program Files\Rhino 6\Plug-ins\IronPython\RhinoDLR_Python.rhp “IronPython” 6.19.19295.1001
C:\Program Files\Rhino 6\Plug-ins\RhinoCycles.rhp “RhinoCycles” 6.19.19295.1001
C:\Program Files\Rhino 6\Plug-ins\Grasshopper\GrasshopperPlugin.rhp “Grasshopper” 6.19.19295.1001
C:\Program Files\Rhino 6\Plug-ins\Toolbars\Toolbars.rhp “Toolbars” 6.19.19295.1001
can you show the output of merge and reverse list component and point list numbers? so I can see which is flipped please.
Basically the value connecting to rectangle component. Plane, x size and y size
Try connecting boolean toggle to True and Connect to Join curves preserve and kindly post the top view.
Willem
(Willem Derks)
December 17, 2019, 12:17pm
16
This is with the join curves previewed
Does this help?
as you can see points/curves are flipped. Is there any method to solve these?
Willem
(Willem Derks)
December 17, 2019, 12:21pm
18
could it be that the trimmed surface that is baked became different from the original one?
can you post that trimmed surface in a file?
Flipped_Curve_bug-01-trimmed-surface.3dm (29.5 KB)
Kindly have a look at the file and please help me to fix it or provide solution so it wont be repeated in future for me.
Willem
(Willem Derks)
December 17, 2019, 12:47pm
20
I did some digging and realized that this is possibly caused by errors due to the boundingbox being flat.
The boundingbox has no height, so the edges have no length.
If the code has to join and sort curves with zero length I would not be surprized that differences in hardware would cause different results.
Try the gh file below and see of this gets similar results on both machines:
Flipped_Curve_bug-01_WD.gh (18.4 KB)
Yes I get similar result like yours. So I use this alternate method instead of bounding box I did?
