I would like to know if I am doing something wrong with the linetype scale, because when I try to print a viewport layout, the dashed lines (of the ‘Center’ type), even with the “Use model units” option activated in the Options, this goes off the determined scale. In the model, the scale looks fine, and in the layout page too, but when I am on the print page, the scale changes:
(Here, I disabled the plus sign hatching, so keep in mind that was me, and this is not related to the issue)
I change the line type, but it still doesn’t work.
I restart the document, but the problem is still there.
I tried to reproduce the problem in another document, but it works fine with the “Use Model Units” option:
I do not really know if I checked some option in Rhino before, so that is where the problem lies, but both documents (with the problem and the simulation) look the same. I do not know what other setting I could enable/disable.
Well, thanks for any help!
By the way, I am using a VisualARQ model (‘meters’ model) in the issue document (sorry about that, I changed the category of this topic). The second one was without the template. Tinkering with it, I realize that when using the model, the scale changes. Therefore, I think this is related to the issue.
