Hidden Lines in Front of Solid Lines in Layouts?
Has anyone encountered this issue when using the “Make 2D” command, where the hidden lines are visible (on screen and in print) over the solid lines? Is there a setting that will correct this?
Hi Ryan,
Use BringToFront or SendToBack to control the draw order. ClearDrawOrder will remove any of these changes if needed.
Thanks Brian!
