Detail objects appear in front of Layout objects
I’ve been having a problem while drafting in my layouts where layout objects (dimension lines, leaders, linework, hatching, etc) are behind the objects in my detail.
Here are two screenshots of how lines in my layout disappear behind the model in my detail - unselected and selected.
A colleague has opened my file on their computer and it’s still happening, I’ve tried copying everything into a new file and it continues, and I’ve tried clearing my Draw Order but that sends all of the layout objects back after using Bring to front and brings the detail views forward.
Hi Aisha -
I’m not seeing that here in a quick test. Could you please run the Rhino SystemInfo command and copy-paste the result here. Also, a simple 3dm file that shows the behavior on your end would help troubleshooting this issue.
Rhino 7 SR30 2023-6-12 (Rhino 7, 7.30.23163.13001, Git hash:master @ f695e494df78377a81b2b95edb99c6067e324b33)License type: Commercial, build 2023-06-12License details: Cloud Zoo
Windows 11 (10.0.22621 SR0.0) or greater (Physical RAM: 16Gb)
Computer platform: LAPTOP - Plugged in [99% battery remaining]
Hybrid graphics configuration. Primary display: Intel(R) UHD Graphics (Intel) Memory: 1GB, Driver date: 2-18-2022 (M-D-Y). > Integrated graphics device with 3 adapter port(s) - Windows Main Display is laptop’s integrated screen or built-in port - Secondary monitor attached to adapter port #1 Primary OpenGL: NVIDIA Quadro P520 (NVidia) Memory: 4GB, Driver date: 2-15-2023 (M-D-Y). OpenGL Ver: 4.6.0 NVIDIA 518.01 > Integrated accelerated graphics device (shares primary device ports) - Video pass-through to primary display device
OpenGL Settings Safe mode: Off Use accelerated hardware modes: On Redraw scene when viewports are exposed: On Graphics level being used: OpenGL 4.6 (primary GPU’s maximum) Anti-alias mode: 4x Mip Map Filtering: Linear Anisotropic Filtering Mode: High Vendor Name: NVIDIA Corporation Render version: 4.6 Shading Language: 4.60 NVIDIA Driver Date: 2-15-2023 Driver Version: 31.0.15.1801 Maximum Texture size: 32768 x 32768 Z-Buffer depth: 24 bits Maximum Viewport size: 32768 x 32768 Total Video Memory: 4 GB
Rhino plugins that ship with Rhino C:\Program Files\Rhino 7\Plug-ins\Commands.rhp “Commands” 7.30.23163.13001 C:\Program Files\Rhino 7\Plug-ins\rdk.rhp “Renderer Development Kit” C:\Program Files\Rhino 7\Plug-ins\RPC.rhp “RPC” C:\Program Files\Rhino 7\Plug-ins\AnimationTools.rhp “AnimationTools” C:\Program Files\Rhino 7\Plug-ins\RhinoRenderCycles.rhp “Rhino Render” 7.30.23163.13001 C:\Program Files\Rhino 7\Plug-ins\RhinoRender.rhp “Legacy Rhino Render” C:\Program Files\Rhino 7\Plug-ins\rdk_etoui.rhp “RDK_EtoUI” 7.30.23163.13001 C:\Program Files\Rhino 7\Plug-ins\rdk_ui.rhp “Renderer Development Kit UI” C:\Program Files\Rhino 7\Plug-ins\NamedSnapshots.rhp “Snapshots” C:\Program Files\Rhino 7\Plug-ins\IronPython\RhinoDLR_Python.rhp “IronPython” 7.30.23163.13001 C:\Program Files\Rhino 7\Plug-ins\RhinoCycles.rhp “RhinoCycles” 7.30.23163.13001 C:\Program Files\Rhino 7\Plug-ins\Toolbars\Toolbars.rhp “Toolbars” 7.30.23163.13001 C:\Program Files\Rhino 7\Plug-ins\3dxrhino.rhp “3Dconnexion 3D Mouse” C:\Program Files\Rhino 7\Plug-ins\Displacement.rhp “Displacement” C:\Program Files\Rhino 7\Plug-ins\NamedPositions.rhp “Named Position”
Here’s a really simple file where you can see the dimension lines in the layout being covered by the model in the detail.
Layout problem test file.3dm (11.9 MB)
Hi Aisha -
Thanks! This appears to be caused by the layer color of the “Glazing” layers. Those are somewhat transparent, and when objects on such layers are used in block definitions, they cause display issues.
I’ve put this specific one on the bug list as RH-75642 Display: Block transparency issue - II.
For now, the workaround is to either use non-transparent colors, or explode the block instances.
