after i draw (poly-) lines, they disappear…
Eike
Eike
Is this in Rhino 6?
Did that just start happening whereas it used to be fine for several months? If so, what was changed?
Could you post the output of the Rhino SystemInfo
command?
Hello - see if un-checking the setting for ‘GPU tessellation’ in Options > View > OpenGL helps.
Hey Pascal,
it works! Thank you!
Eike
Hi Eike - you should probably check the video card maker’s website for a driver update and then try GPU Tessellation again.
