Linear Dimension In Rhino 6 Working Differently
In Rhino 5 I used to be able to dimension height in Perspective by picking two points and then switch to Right view and place a dimension.
In Rhino 6 I am restricted to selecting to points on the same plane even with the planar Onsnap turned off.
Is there any way to change this?
Thanks
Sean
Hi Sean - I see this - I don’t know if this was design change or a mistake, or what, I’ll see what I can find out.
Thanks for the reply Pascal!
Hope you can figure something out.
Hi Sean - it is on the bug pile:
https://mcneel.myjetbrains.com/youtrack/issue/RH-46389
thanks,
