Line weights in layout when clipping style is set by object
Hey!
I’m on Rhino 8 on Mac. This is concering the layout page and print widths of lines.
I was just wondering if there was a way to make the line weight scalable by viewport or some workaround. I have a 1:20 section which clipping boundary is way to thick, however in the 1:1 it is perfect. I’ve tried to change the print widths on the ‘layers’ as well and its never great either way.
I have set clipping style by object so each object has the correct hatch and line weight for full size sections, however on the scaled version the line is always too thick.
Is there a workaround to avoid this? or some setting I’m missing to scale the line weights by viewport perhaps…
I’d rather not set the section style by clipping plane for different viewports, because the wall width needs to be thicker than the objects I’m sectioning and each object has a different hatch - has to be by object.
Help!
Hi Katie -
You can use a linetype that is set to millimeter instead of pixels.
My hero! Thank you so much, this has solved it :smiley:
