Ok, admittedly it’s probably user error, but I have just spent 10 hours measuring lengths of various lines and entering them into a spreadsheet only to find out that something is going wrong right as I thought I was done…
I must have some overlapping lines that are now grouped together and/or joined together and so when I select it and use the _length command, I get an output but I have reason to believe that it isn’t accurate. (one side of a symmetrical shape is longer than the other).
Is there a command where I can look for overlapping lines or otherwise prevent this from happening?
Imagine you have two overlapping straight line segments that share the same endpoints… or maybe there are segments of a curve that are directly ontop of another and visually you can’t see the difference, and if they are grouped they act like one line. This would screw up the _length command. HELP!
Any input would be great.
