Hi all,
I want to measure the length of a line, but both “length” & “distance” seems of no use. After I choose a line and ENTER, nothing happens. It used to work some days ago.
Hi all,
Hello - the result is printed to the command line- if the command line is very narrow, only one or two lines, it may be that the result is one line up - so drag the command area a little taller - 2 or three lines of command history showing. Does that do it?
Thanks, Pascal! That works well in my rhino, never thought the answer could be that simple!
