Limted Patterns on Paneling Tools
Some of these patterns were removed from the default because you can easily create them, and generate a file with your desired patterns. Note that the Hex pattern was added to the default list since we get lots of questions about how to generate… Use ptManage2DPatterns to create the pattern.
I generated 3 pattern for you and saved to a file using ptSave2DPatterns command. you can use ptLoad2DPatterns command to load them. Let me know if anything is not clear. All commands and their options are explained in the Manual.
2DPanelingPatterns.txt (1.2 KB)
