Paneling Tools Wish: Brick Pattern
Could you please add a component for brick pattern in paneling tools. Because it is so common and used all the time should come out of the box I think.
And a reoccurring issue with it is with the ending “bricks”, which always have to be cut.(see image) It would be good if the component would cut them automatically.
Thank you!
Noted.
Hi Rajaa, Is there any update to this component? A preset Random Staggered Pattern would be really helpful.
No update yet. I added this wish to the pile. Will try to get to it in the next update.
https://mcneel.myjetbrains.com/youtrack/issue/PT-192
Hi @rajaa
Is there an update to convert to Brick Patern? 7 years have passed…
Thank you!
It should possible to create the brick patterns and the logic to fill the gaps. See the following example:
Hi @rajaa thank you for your solution.
I still think that it is quite unfriendly to define patterns like this, using numbers.
Instead, much more useful would be to have a component called ConvertTo, with many options: Diamond, Brick, Wave, TriBox, etc.
So users can switch between different patterns just by changing a single parameter.
After all, Panelling Tools is all about making panels fast, and testing different patterns fast.
Thank you for your consideration.
Thanks for elaborating. It is always a balance between keeping the toolset small, and offering more functionality. Will add your comment to the YT
Thanks again.
