License won't allow any saving! - fixed
I recently bought the Rhino educational Version for Mac and it is the first time now that I am using it.
If I try to copy an object an error message pops up saying the command “copy” is deactivated because my license won’t allow any saving.
Also if I try to save a file I can’t even select “save”.
Can someone help me?
Thanks!
Hi @Norma_Kiskan-
Have you validated your license? Run the _ValidateLicense command. (This dialog should come up by default, but it may have gotten dismissed.)
Also, make sure that you’ve entered in your Education license if you have not already. You may still be on the Evaluation license.
Hope that helps,
-Dan
Hello Dan!
The “validatelicense” command worked! Thank you very much!!
