I have a 3d model which had no problem until , for no reason , level manager is not represents plan view or 3d level cutted model correctly.
In the plan view despite that i select one level and activate the cut view , i can see all the levels below and i cannot see the hatches of the cutted objects .
In 3d when i select and isolate one level , is showing all the levels below or above regarding to the viewing angle
Help…
Hi @gmillas1,
Please, could send us the file here or to visualarq@asuni.com? Also, if you can attach some images showing where the problem is and how you are reproducing that would be helpful.
