Less clicks wanted; proposal
Rhino has a fine toolbar system.
A button with a triangle leads to more commands.
We have to click and hold a triangle button to come to the underlying toolbar.
Or click the tiny rectangle.
It could be more comfy and accessible.
Sometimes I (have to) use Xara, which also has the triangle system.
I only need to hover the mouse over such a button, and the toolbar pops out automatically.
A very good system I would like to see in Rhino as well…
The auto-pop doesn’t harm, the top button is still clickable.
What do you think?
Usually these buttons with triangles don’t have right-command and right-click acts as if you’ve clicked the triangle
You can also hold the left click to do the same
No:
I know, see above.
But I don’t want to click at all to get the underlying toolbar.
Yeah, I understand your point.
This is why I said usually :slight_smile:
What I’m doing is dragging that popup into an actual toolbar if I need these commands very often.
Hi Charles - this seems plausible to me except for one thing, which is that the cascading toolbar in Xara replaces the tooltip and I think that tooltip is valuable, maybe indispensable, in Rhino. I’m not sure how to get both.
Yes, the tooltip is very important.
Xara could easily show a tooltip for the triangle button, but it doesn’t.
When a toolbar is popped out, and you move over the triangle button, you can see that it is detected.
A tooltip would be easily possible.
Also the ‘move MRU to top’ is only a source for confusion, no good.
And an adjustable delay before the auto-pop is not there.
I don’t want to focus on Xara.
My proposal is not to copy Xara, it was only easy to explain with this example.
I think this auto-pop would make it much easier to find commands.
And less clicks are always welcome.
+1. The tooltip could show above or below the flyout toolbar.
Hi Jarek - Yeah - that would be the ideal but I am thinking/guessing that the Windows mechanism may not allow two different things to pop out - probably we’d need to figure out a way to combine them - but I don’t know and I’ll let the typists sort that out.
https://mcneel.myjetbrains.com/youtrack/issue/RH-48866
Plus, it has to work with three-row tooltip :wink:
https://mcneel.myjetbrains.com/youtrack/issue/RH-45513
Of course it doesn’t show a tooltip when you hover over the triangle.
Why would you need a tooltip to tell you what happens if you click on the triangle when they have already eliminated the need to click on the triangle?
Very true.
Effective tool-tips would be helpful, as would command options appearing next to the cursor position, mimicing the operability of the ones also showing at the command line.
@pascal
Just want to revive the topic, perhaps there are chances for V8?
And, while we are at that, in Xara the tooltip stays forever (until clicked or other button hovered).
This would be good in Rhino as well.
No it wouldn’t. Tooltips should stay up just long enough for an attentive viewer to acquire it, read it and process it. In other words about 5 seconds at most, but generally proportional to the number of words.
A customizable timeout could be a useful option for the faster or slower readers.
It was possible in Rhino 4.
+1 for the rollout on hover.
just put the tooltip above the button instead of below.
the question is how do you dismiss the menu? does it close immediately when you move the mouse away? sometimes that can get annoying
