Just a simple question. I selected the line icon and linked a toolbar for it to collect all of the commands for 2D editing.
The problem is when I click on the icon the submenu/toolbar appears and shows all of other icons but now I cannot use the righ/left click on the original icon.
The factory settings meanwhile allows me to use the icon and provides a grey triangle in the bottom right corner dedicated to open the toolbar. Now I have the grey triangle but meanless because the toolbar opens when I click on the icon.
Hello- if a button cascades a toolbar on left click, that would mean there is no command in that top level button- if you edit it (Shift-Right click) is there a command string in the left hand panel? If you are dealing with the regular Default toolbars, you can reset to the defaults using ToolbarReset. Restart Rhino and then in Options > Toolbar use the File menu > SaveAs to save the default under a new name to protect it from ToolbarReset in the future if you want to customize it.
Hi pascal, thanks for the answer. It works how you said however I reinstalled the software and regkey (HKEY_LOCAL_MACHINE\Software\McNeel\Rhinoceros) , clicked to Default settings everywhere but no difference. Both RS.12 win 8.1. While splash screen is active and suddenly click onto the icon it works for 1sec.
Hi pascal, Everything looks correct but the functionality of the submenus. When I click ontho the icon the linked toolbar pops up instead run the command. Everything is on default now. However it can be a windows update problem too.
Hi onrender - are you clicking the middle of the button? I only ask because clicking the little triangle in the corner will cascade the nested toolbar.
