Leaves colors of a tree
I try to change leaves colors of tree so i use accurender with this topic
https://rhinolands.com/fr/support/tip/assign-the-seasonal-display-to-plant-species/
but when i click on “change texture” (in red in screenshot) i don’t have an image of the leaf,
i can’t modify the color
@Henry_Boutet_de_Monv have you explored all files in the Leaves folder? from your screenshot it looks like the picture of the leaf is inside the “Single” folder.
@fsalla yes i explored all files and don’t find this leaf
Try to find that picture in this folder: C:\Program Files\Lands Design 6\Plant Editor\Support\Plants\Leaves
I don’t find the buxus leaf in this folder, the leaf seems to be in the file janire.delgado, documents
Lands installer does not distribute all texture files used to create the plants. However, since texture files are embedded into the .ArTree file, you can extract them. Just right-click on the image and select “Save Bitmap to File”:
Hello @albert, ok thanks
I try with a totally black leaf texture but the bush remains green
Sans titre.3dm (4.1 MB)
elaeagnus ebbingei sssssfss
Does the texture look changed in the Plant Editor? If so, please make sure to update the species. To do this, select it from the Selection List in the Edit Panel and click the “Update” button that will appear on the right. This will update the block for this plant.
If the issue persists or is related to the editor, could you please send us both the .3dm file and the .ArTree file you are using?
Hi @Janire, ok thanks i find an easy way with other plants model
