Some of these are probably repeats, but a short list after some layout heavy work:
- Hatching / section line. I know I spoke with @lowell about this, so I won’t rehash it all here, but this is probably the largest time expense for me when creating a drawing. Giving layers the ability to assign hatch “brushes” (for lack of a better word, a combination of hatch styles) which would display when a clipping plane is applied. This should work on non-closed objects as well (perhaps looking at the surface direction to determine which side to hatch)
Dimensions:
Ability to import a block to use as an arrow type
Override individual arrow types (like if I want a tick on one side and an arrow on the other)
Sub-object picking (Shift+Ctrl) for dims to allow assigning different weights or hiding different parts of the dim
Center marks without placing a radial dimension
Ability to import a block to use as a custom center mark
Dimension “hop overs” where I can place an arc in the extension line to hop over another dimension for clarity.
SPELL CHECK (please
Some method of creating reflected ceiling plans, perhaps having a camera that I can place in a bottom view, then assign an X scale of -1 to the camera
Ability to mirror text and hatches without reversing the text or the hatch pattern.
Thanks,
Sam
