Hello
here is my wishlist, which currently is mostly focused on the draughting/layout side of things:
Hatches that have a line pattern and also a solid background colour, much like in Vectorworks
Viewports that have a shape other than a rectangle/square (ie a circle, polygon, or something drawn with the polyline tool)
Is it possible to make a display mode option that create a fill in an apparent closed object? I.E., if the area where the clipping plane is cutting through an object would form a closed polyline if you sectioned through it, this would appear as a fill.
A command to select objects/lines by line weight
An option in the properties dialogue to dictate a hatch pattern for a layer
