Working on some basic layouts today, when I open up the print window and select either save as pdf, or open in preview the page is upside down ?? Anyone else experiencing this, cheers
No.
Max.
more saving PDF’s today, still saving upside down ?
Please provide a copy of your model so we can duplicate what you are seeing. Thanks.
Sola Wall Light (vertical).3dm (306.5 KB)
@marlin Hi Marlin its happened on many files over the last few days, attached is one of the files, cheers
tested with 5.3 and pdf is saved as expected.
I saved your layout as a PDF and it is right side up for me. I am running Rhino 5.2.3.
What is your printer? Does this behave differently if you use a different printer?
What are your Rhino settings? Rhinoceros > About Rhinoceros > More Info… > Copy to clipboard and paste result here.
Untitled.pdf (232.2 KB)
Software information
Software versions
Rhinoceros version: 5.2.3 (5C258)
IronPython version: 5.1.2015.131
Language: en (MacOS default)
OS X version: Version 10.11.6 (Build 15G1004)
Plug-ins
/Library/Printers/hp/PDEs/PDE.plugin/Contents/MacOS/PDE
/Library/Printers/hp/Frameworks/HPSmartPrint.framework/Versions/A/HPSmartPrint
/Library/Printers/hp/PDEs/PDE.plugin/Contents/PlugIns/SmartPrint.plugin/Contents/MacOS/SmartPrint
/Library/Printers/hp/Frameworks/HPDriverCore.framework/Versions/A/HPDriverCore
/Library/Printers/hp/Frameworks/HPDriverCore.framework/Versions/A/Frameworks/DCCore.framework/Versions/A/DCCore
/Library/Printers/hp/Frameworks/HPDriverCore.framework/Versions/A/Frameworks/DCXMLRepository.framework/Versions/A/DCXMLRepository
/Library/Printers/hp/Frameworks/HPDriverCore.framework/Versions/A/Frameworks/DCJobSettings.framework/Versions/A/DCJobSettings
/Library/Printers/hp/Frameworks/HPDriverCore.framework/Versions/A/Frameworks/DCPPDGeneration.framework/Versions/A/DCPPDGeneration
/Library/Printers/hp/Frameworks/HPDriverCore.framework/Versions/A/Frameworks/DCCommunicationServices.framework/Versions/A/DCCommunicationServices
/Library/Printers/hp/Frameworks/HPDriverCore.framework/Versions/A/Frameworks/DCPPDUpdating.framework/Versions/A/DCPPDUpdating
/Library/Printers/hp/Frameworks/HPDeviceModel.framework/Versions/4.0/HPDeviceModel
/Library/Printers/hp/Frameworks/HPDeviceModel.framework/Versions/4.0/Frameworks/HTTP.framework/Versions/4.0/HTTP
/Library/Printers/hp/Frameworks/HPDeviceModel.framework/Versions/4.0/Frameworks/IPP.framework/Versions/4.0/IPP
/Library/Printers/hp/Frameworks/HPDeviceModel.framework/Versions/4.0/Frameworks/ClientUI.framework/Versions/4.0/ClientUI
/Library/Printers/hp/Frameworks/HPDeviceModel.framework/Versions/4.0/Frameworks/DataStore.framework/Versions/4.0/DataStore
/Library/Printers/hp/Frameworks/HPDeviceModel.framework/Versions/4.0/Frameworks/Core.framework/Versions/4.0/Core
/Library/Printers/hp/Frameworks/HPDeviceModel.framework/Versions/4.0/Frameworks/DeviceID.framework/Versions/4.0/DeviceID
/Library/Printers/hp/Frameworks/HPDeviceModel.framework/Versions/4.0/Frameworks/HDT.framework/Versions/4.0/HDT
/Library/Printers/hp/Frameworks/HPDeviceModel.framework/Versions/4.0/Frameworks/Status.framework/Versions/4.0/Status
/Library/Printers/hp/Frameworks/HPDeviceModel.framework/Versions/4.0/Frameworks/PML.framework/Versions/4.0/PML
/Library/Printers/hp/Frameworks/HPDeviceModel.framework/Versions/4.0/Frameworks/XMLServices.framework/Versions/4.0/XMLServices
/Library/Printers/hp/Frameworks/HPDeviceModel.framework/Versions/4.0/Frameworks/Configure.framework/Versions/4.0/Configure
/Library/Printers/hp/Frameworks/HPDeviceModel.framework/Versions/4.0/Frameworks/Fax.framework/Versions/4.0/Fax
/Library/Printers/hp/Frameworks/HPDeviceModel.framework/Versions/4.0/Frameworks/Scan.framework/Versions/4.0/Scan
/Library/Printers/hp/Frameworks/HPDeviceModel.framework/Versions/4.0/Frameworks/XMLServices.framework/Versions/4.0/Resources/axis2_repo/lib/libaxis2_axiom.dylib
/Library/Printers/hp/Frameworks/HPDeviceModel.framework/Versions/4.0/Frameworks/XMLServices.framework/Versions/4.0/Resources/axis2_repo/lib/libaxis2_engine.dylib
/Library/Printers/hp/Frameworks/HPDeviceModel.framework/Versions/4.0/Frameworks/XMLServices.framework/Versions/4.0/Resources/axis2_repo/lib/libaxutil.dylib
/Library/Printers/hp/Frameworks/HPDeviceModel.framework/Versions/4.0/Frameworks/XMLServices.framework/Versions/4.0/Resources/axis2_repo/lib/libaxis2_http_common.dylib
/Library/Printers/hp/Frameworks/HPDeviceModel.framework/Versions/4.0/Frameworks/XMLServices.framework/Versions/4.0/Resources/axis2_repo/lib/./libaxis2_parser.dylib
/Library/Printers/hp/Frameworks/HPDeviceModel.framework/Versions/4.0/Frameworks/XMLServices.framework/Versions/4.0/Resources/axis2_repo/lib/./libguththila.dylib
/Library/Printers/hp/Frameworks/HPDeviceModel.framework/Versions/4.0/Frameworks/XMLServices.framework/Versions/4.0/Resources/axis2_repo/lib/./libneethi.dylib
Third party kernel extensions
None
Hardware information
Computer hardware
Hardware model: MacBookPro11,3
Processor: Intel Core i7-4870HQ CPU @ 2.50GHz
Memory: 16 GB
Architecture: Intel 64 bit
Video hardware
Graphics: NVIDIA GeForce GT 750M 2048 MB
Memory: 2048 MB
Screen size: 1440 x 900
Displays: Color LCD (221dpi 2x)
USB devices
Apple Inc.: Apple Internal Keyboard / Trackpad
Apple Inc.: Bluetooth USB Host Controller
Bluetooth devices
None
OpenGL information
OpenGL software
OpenGL version: 2.1 NVIDIA-10.10.13 310.42.25f01
Render version: 2.1
Shading language: 1.20
Maximum texture size: 16384 x 16384
Z-buffer depth: 24 bits
Maximum viewport size: 16384 x 16384
Implementation settings
Use texture compression: No
Appearance settings
Antialiasing: 4x
Mip map filtering: None
Anisotropic filtering: None
That’s quite a list of HP printer driver files. Can you try your test on another Mac that does not have these HP files installed? We’ve seen layout printing issues in the past when HP drivers were installed.
@marlin Marlin I have no idea what all those driver files are, haha, I only have one HP printer, this saving issue has only just started in the last few days though, I’m afraid I only have this machine, how would i go about removing all those driver files btw ? and is that causing the problem, ?
@marlin update, over the weekend I installed the new Sierra OSX, was saving some more PDF’s today and they saved and opened in preview with no problems, the right way round !
