Layout graphic problems
MCH_Tort karton_20240514 RASTER.pdf (793.7 KB)
MCH_Tort karton_20240514 VECTOR.pdf (152.2 KB)
when switching to rhino 8, I encountered a project failure. So I started making layouts in rhino as usual, but there were some problems that I had not encountered before in rhino 7. Well, in the case of the PEN view, which I liked to use for axonometry, there were problems with lines. So far, I haven’t used additional drawings, I just made views from the model and dimensioned things that way. Now there are some problems with the display of lines, i.e. when I set vector printing, some lines disappear and some appear, although they should not be visible. When changing to raster, the problem disappears, but I am not satisfied with it. Of course, I can make a drawing, but in the case of axonometry, this is problematic. A very small project as an example.
MCH_Tort karton_20240514.3dm (2.4 MB)
Hi Krzysztof -
Thanks for that file.
I’m afraid the only workaround at this point is to use Make2D and place the result in details on the layout.
I’ve added a YT to see if we can disable printing details in technical display modes as vector. That would give the same result as what one would get in Rhino 7.
→ RH-82258 Print: Disable Fake2D when printing
Thanks for your answer, I will try to work out everything in rhino, I have several projects I am working on, maybe I will be able to find a solution :slight_smile: maybe clipping drawing will be such a solution
Thank you for your response - I was about to open a new forum post as I have found the same issue. I have several models with mechanical parts and piping. When I place the details on the layout, it looks great in the technical display mode. Yet when I go to print as a PDF, I have missing lines for seemingly no reason.
This is quite a major blow to me as I have to be able to deliver engineering drawings to our contractors.
If Make2D can be used as a workaround, so be it. That will have to do for me for now.
I do hope this issue can be fixed, however, as being able to use detail views of the actual model in Layouts is so much more powerful than relying on Make2D.
