I have a display problem in layouts when there is a block with transparent layer color.
Leaders are partially clipped:
This screenshot shows a perspective view in a layout and some descriptions with leaders. The pale hole pattern on the panels of this climbing wall are blocks with transparent object color. I need these to be blocks for rendering in keyshot but the color could be solid, which would solve the display problem…
However I think it is a bug which should be solved.
Below is a screen video where I tried to replicate the problem in a simplified file. Once the layer with opacity is off, it looks as expected. Also if the color is solid without opacity, the leader is displayed correctly.
layout_opacity_problem.3dm (297.2 KB)
