layout bug.3dm (142.5 KB)
Hi Andrew - Yeah… this has to do with layout space scaling - you can click-select it at the top left corner. If layout space scaling is turned off, then the text displays as smaller in that corner. It will also select as expected if that view is a parallel one and not a perspective projection.
@mary - is this expected? Seems buggy to me.
Hi @andrew.nowicki,
Thanks letting us know and for including the file.
It shows the issue perfectly, some calculation not being done correctly.
We have logged RH-75634 Text-Selection-Not-Working-In-Perspective-Projection-Detail-with-Layout-Scaling-Enabled
When it is fixed, you will be notified in this Forum thread.
Sincerely,
Mary Ann Fugier
