Layer sorting does not work
I have the feeling that the Layers panel is supposed to allow sorting by clicking a column header. Even if that isn’t explicitly documented, it would be the intuitive behavior.
If clicking the Layer header simply did nothing, I would assume sorting isn’t supported. But I’m seeing behavior that makes me think something is broken:
  • In the Layers panel, click the Layer column header → nothing visibly changes.
  • Run Undo → Command History says: Undoing Layer - sort layers
  • Run Redo → Command History says: Nothing to redo.
So Rhino seems to think a layer-sort operation occurred, but the layer order does not actually change.
Is this expected behavior, or a bug?
Hi Stefano -
It does.
This was broken for a brief period but since there was no public Beta last week, the fix hasn’t been available yet. Hopefully, there will be a public build in about 26 hours from now.
→ RH-98716 Layer: Can’t Sort Anymore
