Layer panel problem
In the re-developing layer panel, I note that it holds focus until you click away from it, which is the same behavior as the notes panel.
This means it breaks the modelling flow, and is certainly not an improvement!
V7 doesn’t do this; simply moving the mouse into a viewport changes the focus there, which is how it should be.
I hope this is a temporary oversight - perhaps when you fix this, you might fix the same annoying bug with the notes panel…?
cheers
rabbit
Hi rabbit - if you mean that when say, a layer is selected and you move the mouse out over a viewport, any typing you do is lost in V8, while in 7 it goes to the command line, that behavior glitch is known, and we’ll get there… if that is not it, I guess explain for 5-year olds…
Thanks Pascal…
It’s a little difficult to know what to flag and what to ignore in the wip…
Explaining for five year olds is actually very difficult, since they ask so many fundamental questions that you soon realise you actually know basically nothing…
cheers
If in doubt, I would always assume flag, not ignore - if we know about it, or it’s not done yet, etc, it is no problem to say so…
thanks,
