Regression - Command line behaviour
In the last beta i found that if i click on the layer panel (for example to change the current layer) in order to prompt a new command i will have to click in the command line to replace the cursor there, otherwise the commands i type on the keyboard will not be written in the line.
In Rhino 7 i did not have this problem, i could touch the layer panel and the text prompt was always active afterwards.
This s a pretty annoying regression to me.
I am new to this forum, i hope i classified correctly my issue.
Thank you in advance,
Enrico
welcome to the forum.
you might want to add tags papercut and bug as tags.
there is similar issues here:
