Hello. I’m recently using v5.x, and trying to recreate a bit of code from a few years ago: baking to layers “dynamically,” using Elefront’s valuable feature of using the Bake Name to revise the baked rhino geometry when new GH geometry is fed in. I think I figured out the setup with the revised component set, but no matter how I configure the Layer, Attributes, Attach Attributes, and Bake components, I can’t change which layer the geometry is getting baked to. It will only bake to the active layer in Rhino.
Here’s a stripped-down view of my code (with all the experimentation deleted out):
First I bake the set of new (sub-) layers, which works fine…but then I can’t figure out how to bake geometry into those layers.
Any thoughts welcome!
