Hi, I’d like to report what seems to be a UI bug in Rhino.
When I select an object and try to change its layer using the layer dropdown menu in the Properties panel, I noticed that the clickable area behaves incorrectly.
The dropdown menu has a variable width depending on the interface layout, so each layer entry appears as a full horizontal row. However, the actual clickable area seems to be limited only to the text label of the layer name.
If I click directly on the layer name text, the object correctly changes to that layer.
But if I click slightly to the right or left of the text — still inside the same row and clearly inside the dropdown entry area — nothing happens, and the layer is not changed.
In other words, the entire row visually appears selectable, but only the exact text area is actually clickable.
This behavior feels inconsistent with standard UI dropdown menus, where the full row should be selectable.
I tested this multiple times and can reproduce it consistently.
Could you please verify whether this is a known bug?
Thanks.
