Layer Color for a Sublayer
How I can have a different color for each sublayer using Grasshopper component when baked in rhino?
For example:
Mainlayer::Sublayer1
Mainlayer::Sublayer2
Mainlayer::Sublayer3
Mainlayer color is white
Sublayer1 color is red
Sublayer2 color is green
Sublayer3 color is blue
Hi @Trevor_Luna
You can use Human for that. Or Elefront
layers.gh (9.5 KB)
Thanks for the response.
I tried it, it produces different colors to the object but I want to bake also the sublayer with its color in rhino.
There are no sublayer baked in rhino.
hi @Trevor_Luna
right click the component and set to “Layer Full Path”
Hi @Trevor_Luna,
In Rhino 8 you can do something like this.
@Erik_Beeren
Even if the component is set to Layer Full Path, the script is still not working. There is an error occuring “Specified Layer not found” which I believe that the layer should be set first in rhino before using this script (correct me if im wrong), but I need the script also to set the layer from the Grasshopper script itself.
Yes, this is the output I need. Thank you.
Also, what component is the one with push content? (Sorry, Im new in using grasshopper).
Sorry @Trevor_Luna
I forgot one component. :sweat_smile:
layers.gh (10.0 KB)
That’s the native component to bake content in Rhino 8 Grasshopper.
