Via a Python script component? Or do I absolutely need something like Elefront?
One approach is to use rhinoscriptsyntax.ObjectColor after adding/baking geometry. Here’s a simple example with adding a point and then setting its color:
210429_ObjectColor_00.gh (2.9 KB)
Yeah, thanks, I had to go look up my documentation on all that, I’m in the process of getting up to speed on it now…
Trying to do this in RhinoCommon, but I’m getting a “Multiple targets could match” when I try to modify the attributes… It works OK outside of the GH environment in the regular Python editor.
import scriptcontext as sc
import Rhino, System
if Bake:
rhobj=rs.coercerhinoobject(Crv)
sc.doc=Rhino.RhinoDoc.ActiveDoc
attr=Rhino.DocObjects.ObjectAttributes()
attr.ColorSource=Rhino.DocObjects.ObjectColorSource.ColorFromObject
attr.ObjectColor=System.Drawing.Color.FromArgb(0,255,0)
sc.doc.Objects.ModifyAttributes(rhobj,attr,True)
sc.doc.Views.Redraw()
sc.doc.Objects.Add(rhobj,attr)
sc.doc = ghdoc
BakeTest.gh (5.2 KB)
rhobj is None when I run your test. But also, doesn’t ModifyAttributes take the guid of a Rhino document object (i.e. and not a RhinoCommon type, which you would get from coercing your Crv input):
This is working:
import Rhino
sc.doc = ghdoc
rhobj = rs.coercerhinoobject(Crv)
geometry = rhobj.Geometry
sc.doc = Rhino.RhinoDoc.ActiveDoc
rhino_obj = sc.doc.Objects.Add(geometry)
rs.ObjectColor(rhino_obj, rs.coercecolor([0,255,0]))
sc.doc = ghdoc
However, when I press the
Bake button, I always get two curves…
Still trying to figure out how to add the color attribs directly instead of going through rs.ObjectColor()
Here’s a pure RhinoCommon solution using the method documented here:
210429_BakeWithColor_RhinoCommon_GHpython.gh (4.3 KB)Was making the same in c# …
private void RunScript(GeometryBase G, ref object A)
Rhino.DocObjects.ObjectAttributes att = new Rhino.DocObjects.ObjectAttributes();
att.ColorSource = Rhino.DocObjects.ObjectColorSource.ColorFromObject;
att.ObjectColor = System.Drawing.Color.Aquamarine;
this.RhinoDocument.Objects.Add(G, att);
Yep, just got to that myself, thanks!! I am still getting TWO objects when I press the bake button though…
Does the button fire once when pressed and again when released?
It does expire the component twice yes (on push down and release), but the script within the Bake scope should only run once (i.e while Bake is True). Which the definition I just posted above does on my system:
Oh, yeah, that was dumb, while testing I took out the if Bake…
Thanks to all who helped, got it working nicely now!! Cheers!
Interesting knock-on effect of this, I thought I would be smart and combine the baking of 3 sets of curve objects in 3 different colors in one component…
Looked fine at first until I started setting a file up to cut - then I suddenly noticed I was getting unexpected dupes on some items. Then it dawned on me - when different sets of curves have different quantities (list length) the bake procedure will run as many times as the longest list - resulting in multiple dupes of the last item in the shorter lists.
Not such a smart idea after all… (dope slap). I’m sure there might be a fancy workaround with some tree helpers here, but for now I’m back to one python bake component per list of curves/color.
BadBakeExample2.gh (11.3 KB)
Hi @AndersDeleuran,
I’m trying out your snippet for baking with colors, that you provided some time back however I have a strange problem.
The curves I bake show up in Rhino and I can select them using Ctrl+A or by a selection window, however I can not select the curves by clicking on them and if I select them using Ctrl+A, the gumball does not show up. So the geometry is only half-interactive. I also tried out the baking component in Human, and interestingly enough, I get the same result.
I’ve been trying to solve the issue for some time now, but without success. Do you have an idea of why I have this problem and how to fix it?
Cheers,
David
I’m afraid I can’t reproduce what you’re describing on my Rhino 8 SR24 install:
I was about to record my screen to show you the problem also using the rectangle. Then however it suddenly worked. I then went back to my initial geometry and realised that it didn’t work with “Line-like Curve” geometries. However, I solved it by running the geometry through a line container.
There have been a lot of new tools in Grasshopper that can help with this. Here is an example of caching to RGB colors various objects:
rgb colors v9.gh (14.5 KB)
