Latest WIP - render command not working
the render window does not appear for me when using the render command in the latest wip.
Rhino 7 SR0 2020-7-28 (Public Build, 7.0.20210.12505, Git hash:master @ f0139f1c5261611d4a836aaeb78840f6535b89b6)
License type: Not For Resale Lab, build 2020-07-28
License details: Cloud Zoo
Expires on: 2020-09-11
Windows 10.0 SR0.0 or greater (Physical RAM: 3.9Gb)
Non-hybrid graphics.
Primary display and OpenGL: Intel® HD Graphics (Intel) Memory: 2GB, Driver date: 1-21-2020 (M-D-Y). OpenGL Ver: 4.0.0 - Build 10.18.10.5129
OpenGL Settings
Safe mode: Off
Anti-alias mode: 4x
Mip Map Filtering: Linear
Vendor Name: Intel
Render version: 4.0
Shading Language: 4.00 - Build 10.18.10.5129
Driver Date: 1-21-2020
Driver Version: 10.18.10.5129
Z-Buffer depth: 24 bits
Total Video Memory: 2104186 KB
C:\Program Files\2Shapes for Rhino\7.0\2Shapes.rhp “2Shapes” 0.1.3.1
C:\Users\keith\AppData\Roaming\McNeel\Rhinoceros\packages\7.0\IntelDenoiser\0.1\IntelDenoiser.Windows.rhp “IntelDenoiser.Windows” 0.1.0.0
C:\Program Files\Rhino 7 WIP\Plug-ins\Commands.rhp “Commands” 7.0.20210.12505
C:\Program Files\Rhino 7 WIP\Plug-ins\rdk.rhp “Renderer Development Kit”
C:\Program Files\Rhino 7 WIP\Plug-ins\RhinoRenderCycles.rhp “Rhino Render” 7.0.20210.12505
C:\Program Files\Rhino 7 WIP\Plug-ins\rdk_etoui.rhp “RDK_EtoUI” 7.0.20210.12505
C:\Program Files\Rhino 7 WIP\Plug-ins\rdk_ui.rhp “Renderer Development Kit UI”
C:\Program Files\Rhino 7 WIP\Plug-ins\NamedSnapshots.rhp “Snapshots”
C:\Program Files\Rhino 7 WIP\Plug-ins\RhinoCycles.rhp “RhinoCycles” 7.0.20210.12505
C:\Program Files\Rhino 7 WIP\Plug-ins\Toolbars\Toolbars.rhp “Toolbars” 7.0.20210.12505
C:\Program Files\Rhino 7 WIP\Plug-ins\3dxrhino.rhp “3Dconnexion 3D Mouse”
C:\Program Files\Rhino 7 WIP\Plug-ins\Displacemen
check for an update, I believe we had a temporary bug in v7 rendering recently.
Thanks @theoutside, i am running the latest wip - not sure if it is related rhino also crashes when i switch my display to raytraced.
more likely related to the intel hd graphics in your machine… it does not meet our min spec (4gm vram) and is notorious for being troublesome with rhino. If you are going to be doing any serious work you need to upgrade to a machine built to handle rhino with a standalone graphics card (Nvidia gtx, rtx or quadro will be your best choices there as long as they have 4gb vram minimum)
if i disable the intel denoiser then i can render again and use raytraced.
your intel may be too old for the denoisers… if I remember correctly they were a bit picky on which intel hd they’d work on…
@andy ? am I wrong here?
looks like denoiser minimum is Intel® SSE4.2 - might be worth adding a warning and avoid the crash.
