Last Kick at HoloMark2 beta
My score went from 23,000 to 30,000 by building a new system with i7-4820K CPU @ 3.70GHz.
So I changed Graphic Card from GeForce GTX 750 Ti - to - Quadro K4000 - 3072.0 MB and here is the first result: HoloMark2-04.txt (1.9 KB)
I almost made 36,000… and I wondered if I could improve this with some additional adjustment and understanding. One thing I am doing which I don’t feel is correct is that I am using a DVI to HDMI adapter (as it is not mentioned anyware in the setup sheet) they want either “Desplay Port” or Display Port via a DVI to Display Port Adapter (there is one DVI and two Display Ports on the back of the K4000)
My question is “does reducing the output to HDMI change anything”? Plus anything else you would like to add.
Greg
