Lagging and Weird Glossy Object
I found the file become super lag suddenly. And the object turn very glossy in shaded mode but I didn’t change any setting. Also, the glass material also turn transparent in shaded mode which is not the default setting I got. Noted that the file is just 450Mb. Any idea?
https://drive.google.com/file/d/1ItMZEmiqVPTmaWvamRIc2jr3JscLg1gj/view?usp=sharing
Hi Jack- I am taking a look - note you have posted your file in a publically accessible link - is that what you intended?
The posted file is missing many many blocks so it may not show the problem - it seems OK here.
Oh yeah I forget those linked block. The problem is fixed now after I turned off my cpu for some time, maybe it is a little bit overwhelming. Thanks
Hi, I actually have a similar issue with Rhino no matter what model I open. I tried restarting my computer and even reinstalling Rhino, without any success.
Hi Cyrille - can you please run the SystemInfo command in Rhino and post the results?
Rhino 7 SR20 2022-7-12 (Rhino 7, 7.20.22193.09001, Git hash:master @ 9b19bfdb8c343dd6fa8df3514068defd72273d6f)
License type: Commercial, build 2022-07-12
Windows 10 (10.0.18363 SR0.0) or greater (Physical RAM: 32Gb)
Computer platform: LAPTOP - Plugged in [92% battery remaining]
Primary display and OpenGL: Intel(R) UHD Graphics 630 (Intel) Memory: 1GB, Driver date: 5-13-2022 (M-D-Y). OpenGL Ver: 1.1.0
Secondary graphics devices.
NVIDIA GeForce RTX 2080 with Max-Q Design (NVidia) Memory: 8GB, Driver date: 6-23-2022 (M-D-Y).
- This device is not being used
ATTENTION:
No graphics device is being used. Either an error occurred on startup, or certain devices have been disabled.
See below for any possible configuration changes that may help resolve this issue.
  • Any hardware configuration or cabling changes you make will require that you restart Rhino.
OpenGL Settings
Safe mode: Off
Use accelerated hardware modes: Off
Graphics level being used: OpenGL 1.1 (software driver)
Anti-alias mode: None
Mip Map Filtering: Linear
Vendor Name: Microsoft Corporation
Render version: 0.0
Shading Language: Not supported
Driver Date: NA
Driver Version: NA
Maximum Texture size: 1024 x 1024
Z-Buffer depth: 32 bits
Total Video Memory: 64 MB
C:\ProgramData\Proving Ground\Conveyor\ProvingGround.ConveyorRhino\ProvingGround.ConveyorRhino.rhp “Conveyor Rhino Setup” 2020.4.29.0
C:\ProgramData\Proving Ground\Semantic\Rhino6\SemanticV6.rhp “Semantic for Rhino 6” 2020.4.29.0
C:\Program Files\Enscape\Bin64\Enscape.Rhino7.Plugin.dll “Enscape.Rhino7.Plugin” 0.0.22102.1509
c:\Program Files\Solemma\ClimateStudio\bin\ClimateStudioRhino.rhp “ClimateStudioRhino” 1.7.8080.15319
C:\Program Files\Chaos Group\V-Ray\V-Ray for Rhinoceros\V7\VRayForRhino.rhp “V-Ray for Rhino”
C:\Users\futchac\AppData\Roaming\McNeel\Rhinoceros\packages\7.0\Bullant\1.5.12.0\bullant.rhp “bullant” 1.5.12.0
C:\Program Files\Rhino 7\Plug-ins\Commands.rhp “Commands” 7.20.22193.9001
C:\Program Files\Rhino 7\Plug-ins\RhinoRenderCycles.rhp “Rhino Render” 7.20.22193.9001
C:\Program Files\Rhino 7\Plug-ins\rdk_etoui.rhp “RDK_EtoUI” 7.20.22193.9001
C:\Users\futchac\AppData\Roaming\McNeel\Rhinoceros\7.0\Plug-ins\PanelingTools (6caed836-bc06-4ebc-b1fd-e10886a0dc94)\2018.12.17.906\PanelingTools.rhp “PanelingTools”
C:\Program Files\Rhino 7\Plug-ins\RhinoCycles.rhp “RhinoCycles” 7.20.22193.9001
C:\Program Files\Rhino 7\Plug-ins\Toolbars\Toolbars.rhp “Toolbars” 7.20.22193.9001
Hi Cyrille - I would get this working correctly first - if that does not do it, we’ll look at the various plug-ins. Make sure your monitor is seeing into the RTX card and not just the Intel gpu.
tried to reply to your message to tech support but it bounced as undeliverable.
feel free to call us at 206-545-6877
see below-
it looks like your graphics card is not working correctly.
3 possibilities-
  1. your graphics card has failed and the hardware died.
  2. your graphics driver in incorrectly installed and needs to be replaced with a clean install.
  3. your graphics card driver settings are non typical and are allowing the intel card to take over.
see this thread-
This reply chain did not really help me figure out how to get rid of the glaring/shiny effect that I am getting in my 3D models. I do not have any materials or lighting in my model. I do not always face this problem in each model I have created. My system info differs from what was posted before so I am attaching the details below.
Could you please suggest some different solutions?
Thank you!
Rhino 8 SR9 2024-7-12 (Rhino 8, 8.9.24194.18121, Git hash:master @ 785b9fde79bb684d22aab317998f7195a8c27c14)
License type: Commercial, build 2024-07-12
License details: Cloud Zoo
Windows 11 (10.0.22631 SR0.0) or greater (Physical RAM: 63GB)
.NET 7.0.20
Computer platform: DESKTOP
Primary display: AMD Radeon™ Graphics (AMD) Memory: 1GB, Driver date: 1-11-2024 (M-D-Y).
> Accelerated graphics device with 5 adapter port(s)
Primary OpenGL: NVIDIA GeForce RTX 4070 (NVidia) Memory: 12GB, Driver date: 7-12-2023 (M-D-Y). OpenGL Ver: 4.6.0 NVIDIA 536.67
- Secondary monitor attached to adapter port #0
OpenGL Settings
Safe mode: Off
Anti-alias mode: 4x
Render version: 4.6
Shading Language: 4.60 NVIDIA
Driver Date: 7-12-2023
Driver Version: 31.0.15.3667
Z-Buffer depth: 24 bits
Total Video Memory: 12282 MB
C:\Program Files\Rhino 8\Plug-ins\Commands.rhp “Commands” 8.9.24194.18121
C:\Program Files\Rhino 8\Plug-ins\RhinoRenderCycles.rhp “Rhino Render” 8.9.24194.18121
C:\Program Files\Rhino 8\Plug-ins\RhinoRender.rhp “Legacy Rhino Render”
C:\Program Files\Rhino 8\Plug-ins\rdk_etoui.rhp “RDK_EtoUI” 8.9.24194.18121
C:\Program Files\Rhino 8\Plug-ins\MeshCommands.rhp “MeshCommands” 8.9.24194.18121
C:\Program Files\Rhino 8\Plug-ins\RhinoCycles.rhp “RhinoCycles” 8.9.24194.18121
C:\Program Files\Rhino 8\Plug-ins\Toolbars\Toolbars.rhp “Toolbars” 8.9.24194.18121
