Just upgraded my computer to a amd 2920x and 2080ti gpu so Im confused why Im getting crazy lag with such things like moving objects, ctrl+shift selection windows for solids, and dimension, etc. Even my 5 year old laptop works better. Please help! Is it settings? See this videoā¦in the first bit, I show the dimensions problem, and in the last bit the major lag with ctrl+shift selection of a surface. Help!
https://peterrz.tinytake.com/tt/MzYzODU1N18xMTAyNDcyNQ
Hi Peter - if the machine is new, please make sure to update Windows and the graphics drivers, if you have not - drivers are unlikely to be the latest on a new machine.
Also please run the SystemInfo
command in Rhino and post (copy/paste) the results here.
Hi Pascal. I updated the graphics driver last week and windows is new, so itās up to date.
Thank you\ for looking into this.
Hereās the systeminfo:
Rhino 6 SR15 2019-6-13 (Rhino 6, 6.15.19164.21011, Git hash:master @ e41c99d36bb5000377057645e96b3ea6facf6171)
License type: Commercial, build 2019-06-13
License details: Cloud Zoo. In use by: Peter ()
Windows 10.0 SR0.0 or greater (Physical RAM: 32Gb)
Machine name: DESKTOP-PJ0U1NE
Non-hybrid graphics.
Primary display and OpenGL: NVIDIA GeForce RTX 2080 Ti (NVidia) Memory: 11GB, Driver date: 5-22-2019 (M-D-Y). OpenGL Ver: 4.6.0 NVIDIA 430.86
OpenGL Settings
Safe mode: Off
Anti-alias mode: 4x
Mip Map Filtering: Linear
Render version: 4.6
Shading Language: 4.60 NVIDIA
Driver Date: 5-22-2019
Driver Version: 26.21.14.3086
Z-Buffer depth: 24 bits
Total Video Memory: 11 GB
Rhino plugins
C:\Program Files\Rhino 6\Plug-ins\SolidTools.rhp āSolidToolsā
C:\Program Files\Rhino 6\Plug-ins\Commands.rhp āCommandsā 6.15.19164.21011
C:\Program Files\Rhino 6\Plug-ins\rdk.rhp āRenderer Development Kitā
C:\Program Files\Rhino 6\Plug-ins\RPC.rhp āRPCā
C:\Program Files\Rhino 6\Plug-ins\RhinoLabsTools.rhp āRhino Labs Toolsā
C:\Program Files\Rhino 6\Plug-ins\AnimationTools.rhp āAnimationToolsā
C:\Program Files\Rhino 6\Plug-ins\RhinoRender.rhp āRhino Renderā
C:\Program Files\Rhino 6\Plug-ins\rdk_etoui.rhp āRDK_EtoUIā 6.15.19164.21011
C:\Program Files\Rhino 6\Plug-ins\rdk_ui.rhp āRenderer Development Kit UIā
C:\Program Files\Rhino 6\Plug-ins\NamedSnapshots.rhp āSnapshotsā
C:\Program Files\Rhino 6\Plug-ins\RhinoCycles.rhp āRhinoCyclesā 6.15.19164.21011
C:\Program Files\Rhino 6\Plug-ins\Toolbars\Toolbars.rhp āToolbarsā 6.15.19164.21011
C:\Program Files\Rhino 6\Plug-ins\3dxrhino.rhp ā3Dconnexion 3D Mouseā
C:\Program Files\Chaos Group\V-Ray\V-Ray for Rhinoceros 6\VRayForRhino.rhp āV-Ray for Rhinoā
C:\Program Files\Rhino 6\Plug-ins\BlockEdit.rhp āBlockEditā 6.15.19164.21011
C:\Program Files\Rhino 6\Plug-ins\Displacement.rhp āDisplacementā
Hi Peter -
This is what jumps out at me - to test, try disabling Vray in Options > Plug-ins page and then restart Rhino.
Done. Unfortunately that didnāt help. Still lagging.
OKā¦ can you bear with me and just verify that Vray is not loaded when you start Rhino? Just making sure because your description matches, to my recollection, symptoms that appeared to be related to Vray in other cases.
how do i confirm?
Sorry - open Options > Plug-ins page and look for that plug-in - it should not be enabled (check box) or loaded.
Oh, and you might get the latest SR of Rhino too - 6.16 is current.
Thanks. Confirmed. The vray plugin is unchecked. Also, currently on 6.15ā¦and update says Im current.
If you have any other suggestions, Im all eyes
Uncheck all plug-ins?
Ill try itā¦ but for a computer this powerful to run weaker than my old laptop ā¦ Im speechless
Hi Peter - first, start in Safe Mode
Start Rhino in Safe Mode: Windows start menu, type in āRhinocerosā and look for the āRhinoceros in Safe Modeā entry.
And see how things behave. This is a test mode and not meant to be a working mode.
Does the problem you are seeing happen in any file - like a new file with a few objects added - or only some files?
Thanks Pascal. Im working on a new file now so things are ok, but still a bit slugish in layout when I make views using arctic mode. Are there any windows settings to ensure my computer is being used to itās full potential? Anything Im missing maybe in rhino settings? Do I set the ārhino render optionsā maybe? I donāt know what I donāt know, you know what I mean? What am I missing? I just donāt believe that this computer would run a fresh install of rhino slugishly.
R6 UI is noticeably slower than R5. I notice it here too. I know that it attributes to bunch of neat features like RichText formatting and such. Display though should be much faster.
