Hello McNeel community and @DanielPiker ,
Could you check my rhino file or image below to give me an idea if I can fold this pattern with kangaroo or not? If it is possible, how should I define the naked edges, mountains and valleys? many thanks in advance
pattern-for-kangaroo.3dm (685.0 KB)
Hello
I didn’t look at your file but it looks like Origami. You will find some recent talking here
Hi everyone,
I am trying to create a script for the yoshimura pattern (origami) and am stuck within my script. I have built up the script so it is completely parametric, starting off with the creation of a base module and then copying these into a pattern. Now copying in the x direction is easy since the kinematics remain the same, however copying to the y direction gives problems as when folding this pattern it automatically should fold into a barrel vault. This means there is a rotation neede…
Hi Daniel,
I am modeling a Yoshimura origami using your grasshopper example.
My Pattern is as shown above: Mountain in orange and valleys in green.
[1]
In addition to your origami example, I also add some boundary conditions:
-both edges should be at the plane OXY
-both edges should be parallel to each other
[2]
[3]
When a set my folding amount to 0, my origami is flat. However, if I set it to 1, it is not completely folded. Could you explain me why does it happen? Is it possible to f…
For kirigami see there
