Hi everyone. I am trying to make animation in Rhino using Bongo evaluation version. For some reason, after i saved and closed project, when i reopened it all my keyframes are gone. The animation itself is still working, but i did not finish making it. It is my first time using bongo, maybe i miss some kind of checkbox.
Found a workaround. You need to press “play dead” command, and then press “display timeline”
This is unfortunately caused by a bug in Rhino 8 combined with high res screens RH-78973. If you close and reopen the Timeline, the ticks should be back (BongoPlayDead will do that since it closes down all of Bongo).
Thank you!
