Keyboard input goes to Rhino instead of Grasshopper
For some scripts after using it for a short while the keyboard input is send to Rhino in stead of Grasshopper. For example if I use hotkeys or change a slider the input shows up in the command line of Rhino. I have to restart Rhino to fix it, but is happens again and again. What could cause this or how can I solve it?
It seems to happens more often when using an second screen or remote desktop.
Gr,
Peter
Not sure what your scripts do but I have a similar situation:
I’m using keyboard shortcuts and Elefront to bake geometry. When baking into a shaded viewport, the cursor goes from GH to Rhino because Rhino has to create render meshes. My solution is to bake into a wireframe viewport.
I often double click the GH canvas to type and the text goes to the Rhino command line. I don’t know why the focus keeps switching to Rhino despite working in GH but it often does.
When this happens, I use the corresponding menu items, if possible, until it become too exasperating. Closing and reopening Rhino will restore normal functioning – until next time.
Happens often also to me.
I think it’s because the keyboard is listened by rhino, mainly. Grasshopper starts picking keyboard inputs only when you have a text input form active.
For example with double-click it opens the GH search tool, but if you input a key too early, rhino get it and the search function close.
We should just learn to start the search function with the bar space :sweat_smile:
Anyway the problem also occur in different situations.
If it is not problem sharing them, do so.
Scripts can do anything, it’s hard to tell. It’s easy to break gh/rhino UI with scripts.
Best fix for your problem would be to edit those scripts.
Hi having the shame problem.
What i do is close and open rhino
Did someone had any success to find better solution?
Thank you,
I also have the same issue, closing and opening Rhino is the only solution I have so far. Haven’t yet noticed what causes it, but it occurs about once or twice a week.
If it is not a button causing the problem, I double click on the window on the top, to minimize it and than again, to maximize. After that it works for me.
Yes, spamming windows+D button a few times fast usually fixes it.
yep, for me too
